Hello Guest it is October 28, 2026, 06:27:50 AM
Author Topic: Need Help with MPGs?  (Read 226713 times)
0 Members and 5 Guests are viewing this topic.
« on: September 02, 2026, 04:03:30 PM »
Hello,
I want to install a new control system on my lathe. I am using Windows XP, Mach3, and a PoKeys57E. I wanted to connect the handwheels now. I connected the first one to I/O pins 1 and 2; it is recognized in Mach3 Diagnostics and counts up and down correctly.
I connected the second MPG in the same way, but it isn't being recognized by Mach3. I used an oscilloscope to verify that the MPG is working. I also tried connecting it to different pins,
but it still doesn't work. Does anyone have any ideas?
Hans
Re: Need Help with MPGs?
« Reply #1 on: September 03, 2026, 05:12:28 AM »
In the setup from the PoKeys57E both MPGs are working, both count up and down. In the diagnostics from Mach3 works
only MPG 101.
