Hello Guest it is October 21, 2026, 06:36:07 PM
Author Topic: BUG? Axis A not homed... but I have no A axis  (Read 2525 times)
« on: July 10, 2026, 01:17:37 PM »
Hi, first time post long time lurker. Looking forward to learning where I’ve gone wrong.
I recently purchased and installed Machpro and I am looking forward to using it with my CNC knee mill. However, I have yet to get it fully functioning. The profile I’m running was imported from Mach4, where it was working fine. After running the homing sequence the first thing I tried was fire off a simple XY move (G01 X1 Y1 F10) via the MDI button. But nothing moves and I get an error in the status box stating “Axis A must be homed before running G-code”. I thought I could get by without the MDI but the error pops up while running a g-code file and when I was setting up my auto tool setter.
Nowhere in my settings is Axis A, or Motor 3, enabled. And in settings under Safety Check - Ignore Axes Homing Safety Check I have tried both “3” and “3-5”.
I went so far as to make an entirely new profile from scratch. That profile is throwing errors for a door interlock safety and a low coolant switch, neither of which I have. And for the record they are disabled in the settings section and no inputs were ever set for them. Also for the record, the motors are working as I can home and jog to my hearts content.
It won't let me attach files but below is the diagnostics log.
2026-07-06 12:57:49.419
  • [I    ] - Logging Enabled.
2026-07-06 12:57:51.134
  • [I    ] - Cycle Start Button Pressed  Line
2026-07-06 12:57:51.135
  • [I    ] - Function: SetStopStatus():  completed successfully, called by: SetStopStatusAll(), (inst = 0) ?
  • [I    ] - Function: SetStopStatusAll():  completed successfully (inst = 0) ?
  • [I    ] - Function: ResetAllOverrideAxes():  completed successfully (inst = 0) ?
  • [I    ] - Function: ResetEndOfProgramOutput():  completed successfully (inst = 0) ?
  • [I    ] - Function: LaserPointerCycleStartCheck():  completed successfully (inst = 0) ?
  • [I    ] - Function: GetSoftLimits():  completed successfully, called by: CycleStartSoftLimitRecovery(), (inst = 0) ?
  • [I    ] - Function: CycleStartSoftLimitRecovery():  completed successfully (inst = 0) ?
2026-07-06 12:57:51.136
  • [I    ] - API: mcCntlMdiExecute(inst = 0, commands = 'G01 X1 Y1 F10') (unknown caller)
  • [I    ] - Force home check failed: axis A is not homed.
  • [I    ] - API: mcCntlMdiExecute() Force home check failed! Returned MERROR_NOT_NOW.
  • [I    ] - Error: The operation could not be completed at this time. Return Code: MERROR_NOT_NOW (-18), Function: ExecuteMDI(), Called by: xpcall(), File: [C], Line: -1  Line
  • [I    ] - Error: The operation could not be completed at this time. Return Code: MERROR_NOT_NOW (-18), Function: _CycleStart(), Called by: pcall(), Line: -1  Line
2026-07-06 12:57:57.682
Any help is appreciated! Thank you!
« Last Edit: July 10, 2026, 01:23:08 PM by Sunkistist »
Re: BUG? Axis A not homed... but I have no A axis
« Reply #1 on: July 20, 2026, 05:32:28 AM »
I'm having the same issue with my upgrade from Mach4 Hobby to MachPro.
My install is running an ESS motion controller.
What is yours?
Wondering if there is something amiss in that department.
Phil
« Reply #2 on: July 20, 2026, 12:19:21 PM »
Sorry to hear you're in a similar boat. Yes, I've got an ESS with an MB3. My guess is there's something going on where the import profile doesn't get it quite right.
I found a work around I'm not proud of but my machine is working. I gave up hunting settings and just enabled Motor3 and assigned it to the a axis, made sure it was set to "home in place" and then assigned some unused output ports on the ESS to the motor. Learning from a different issue I believe there's some setting buried in the config --> settings that is associated with the a axis, but not labelled as such, that would make the program think it needs an a axis.
Cheers,
« Reply #3 on: July 20, 2026, 02:46:42 PM »
Yep, I've done the same thing.
On digging a bit deeper, there are suggestions that it could be directly associated with the screen design.
Further research required.
Phil
« Reply #4 on: August 12, 2026, 10:41:44 AM »
MachPro wants all enabled axis to be referenced before any controlled motion can start happening. This is purely for safety as we need to know where the machine is before we can start going.
If A axis is enabled in either the M31 Plugin or enabled in the (Version Depending) Axis or the Axis Mapping sections, then you will get these issues. One way around it, is to just enable home in place on the plugin and in the control → config. But I would recommend checking your Axis mapping and your plugins first to verify that no motor or axis is actually mapped.
Paul
« Reply #5 on: August 12, 2026, 02:43:46 PM »
Thanks Paul
I've carried out your suggestions but I still get the same issue.
This is with a Warp9 ESS controller so the issue may lie with it's plugin.
Regards
Phil
« Reply #6 on: August 13, 2026, 09:01:34 AM »
What version of the plugin are you running? I can follow up with Warp9 and check.
Paul
« Reply #7 on: August 13, 2026, 10:10:19 AM »
I just finished some ESS testing on a default setup and did not experience these issues. Could I get the machine.ini file so that I may review your setups?
Paul
« Reply #8 on: August 13, 2026, 03:53:06 PM »
Hi Paul
I've gone back over my settings and I must have missed something originally as now I can disable the A axis completely and I do not get the "homing" message.
So, for me, all fixed.
Thanks and cheers
Phil
« Reply #9 on: August 21, 2026, 04:05:02 PM »
Sweet deal, glad to hear that!
Paul
