Hello Guest it is October 22, 2026, 03:50:34 PM
Author Topic: Spindle won't stop with M5 or Reset (Mach3)  (Read 3769 times)
« on: April 10, 2026, 06:13:49 AM »
Hi, I have a CNC machine running Mach3.
The machine was already wired when I got it, I don’t have documentation. :(
Everything works (X, Y, Z axes), and the spindle starts with M3.
BUT:
The spindle DOES NOT STOP with M5, Stop, or Reset.
It only stops when I close Mach3.
I tried:
- Active Low on/off
- Different Output pins (Port 1 Pin 16 etc.)
- Spindle setup settings
Current setup:
- Output #1: Port 1 Pin 16
- Spindle Relay enabled
- Using relay (not sure about VFD)
Question:
Why would spindle ignore M5 and keep running?
Is this wiring issue or Mach3 configuration?
Thanks!
Offline TPS
  •  2,627 2,627
Re: Spindle won't stop with M5 or Reset (Mach3)
« Reply #1 on: April 18, 2026, 06:32:14 AM »
go to diagnostic page in screen and check what LED for Output1 is doing.
