Hello Guest it is October 30, 2026, 08:48:57 AM
Author Topic: Mem map file sharing exception error - ToolDisplay0.dat  (Read 93318 times)
Offline Azalin
  •  191 191
« on: March 30, 2026, 01:53:35 PM »
I get this error almost every time I click the "View Toolpath" button in canned cycles.
Mach4 Hobby Lathe
Mach4 4.2.0.5036 (latest)
Is there a fix or workround?
Offline Azalin
  •  191 191
Re: Mem map file sharing exception error - ToolDisplay0.dat
« Reply #1 on: March 31, 2026, 05:40:06 AM »
Probably the consecutive call for mcToolPathGenerate() method is causing this error.
Any ideas?
Offline Azalin
  •  191 191
« Reply #2 on: April 01, 2026, 11:06:54 AM »
Nobody's using Mach4 anymore? wow. Anyway I fixed the problem by adding a monkey patch into the screen set. Works well.
  •  9,375 9,375
« Reply #3 on: April 02, 2026, 01:00:46 AM »
I am pleased that you found a fix.
There are still plenty of people using Mach4 it is just that the software developer's support for the product ended way back and many of the regular contributing forum members have just drifted away, possibly as a result.
« Last Edit: April 07, 2026, 12:53:18 AM by Tweakie.CNC »
