Hello Guest it is November 26, 2026, 04:44:25 AM
Author Topic: Out of Band Axis Setup  (Read 61030 times)
« on: March 12, 2026, 10:55:29 PM »
Hey folks, I'm in the process of setting up a CNC plasma table using Mach4. From the Plasma_Configuration PDF included in the docs folder, I can see that I need to configure the torch height controller to use an Out-of-Band (OB) axis. But, I can't find any documentation elsewhere for how to actually set that up.
My Z axis is configured for motor 2. I've copied those settings to Motor 3:
And I've told Mach4 to use Motor3 as OB1 (axis 6):
And I've configured the THC to use axis 6:
What I can't figure out is: How do I tell Mach4 that motion commands intended for Motor 3 should actually move Motor 2?
This feels like something I might need to configure at the motion controller level (I'm using a PMDX-411, plugged into the PMDX-122 that we used to control the machine with Mach3) but PMDX's forums are down so I can't ask there. Hopefully I'm missing something obvious in Mach4?
« Last Edit: March 12, 2026, 11:02:58 PM by ecapstone »
Re: Out of Band Axis Setup
« Reply #1 on: March 20, 2026, 01:45:59 AM »
Is it possible that I'm overcomplicating things here? Does Mach "just know" that the THC should move the Z axis, and the out-of-band axis is for bookkeeping?
