Hello Guest it is October 28, 2026, 08:48:00 AM
Author Topic: Modbus Input Holding Not Reading in Brains  (Read 96365 times)
« on: March 07, 2026, 03:54:51 PM »
Set up Mudbus RTU to Servo Drive to read and write holding registers.  I can run "Test Modbus" without any issues, all requested input and outputs read and write correctly.  I have setup my Modbus configuration using the same parameters.  Created and Enabled a simple Brain that compares the CFG(0) Modbus input to turn off/on an output but I only get 0.0000 in my Modbus Reading.  Have also tried similer ouput (CFG)'s and Brains, it only wants to send 0.0000.  Any ideas what I am missing???
Thank You,
Brandon
« Last Edit: March 07, 2026, 04:06:54 PM by BSRHAANN »
