Hello Guest it is November 26, 2026, 04:44:31 AM
Author Topic: Mach4 - C82 - PlasmaSensOut - Z axis  (Read 243784 times)
0 Members and 11 Guests are viewing this topic.
Re: Mach4 - C82 - PlasmaSensOut - Z axis
« Reply #10 on: March 17, 2026, 02:44:33 PM »
Our THC does something called Axis Override.. It uses a fake or false motor to handle the Jog velocity moves of your Z axis. In rare cases, some may want to have a separate Steps per Unit for their THC. When your THC tells Mach it wants to go up or down, you get this Axis override command to command Z in its stead.  All this logic is handled inside of your M3 macro. So when you call M3, it will start looking for the up or down commands after we have ARC OKAY and we get past to the "Cut" Sequence of the torch.
Paul
« Reply #11 on: March 31, 2026, 03:34:58 PM »
Do I have to edit the macro somehow? Or is the macro created on OB1 motor 5 and I just need to create motor 5? In the G code program, does the M3 command have to be called somewhere, or does Mach 4 automatically call the macro when the signal from THC up or down comes?
« Reply #12 on: April 01, 2026, 11:12:36 AM »
M3 or M03 is the same as turning your spindle on a standard system.
The same is done for Plasma, M3 or M03 should make the attempt to turn your Torch on.
Once your Torch is on and you have an ARC OKAY signal, your THC should work its magic.
In the configuration side have Motor2 set up as your Z Axis and have Motor5 enabled and setup as your OB1 Axis. Steps per unit, Acceleration, Max Velocity and direction should all be the same between the two motors.
From your TCH, you should have 3 wires coming to your Motion Controller (Sometimes this is a cable.) These three wires should be ARC OKAY, UP, DOWN.
Inside of your Mach Inputs Config, you will have 3 inputs available for THC. THC ON, THC UP, THC DOWN. ARC OKAY is your THC ON, UP is your THC UP, and DOWN is your THC DOWN.
These three signals control your Torch Height after the probing and Torch ON Sequence.
If this is set up correctly and you have the proper target voltage in your THC, you should have no issues with Torch Height.
By default on the plasma profile, you should not have to modify your M3 macro.
Paul
« Reply #13 on: April 01, 2026, 03:55:51 PM »
That's what annoys me the most about it. Everyone else does it without doing anything and I don't at all. I tried it now exactly as you wrote these settings and the result is the same. I'm attaching a video and a few pictures with the settings. I had to upload the video to storage because it's bigger.
video:
https://www.uschovna.cz/sk/zasilka/UWLX89CNLFAUWJZM-P39/
« Reply #14 on: April 01, 2026, 03:57:50 PM »
foto 01
« Reply #15 on: April 01, 2026, 03:58:56 PM »
foto2
« Reply #16 on: April 06, 2026, 09:43:58 AM »
Is that the Smooth Stepper Screen?
Also can I get logging data when you do that? make sure that you have all of the options selected for it.
THC controls will not affect your Z axis DRO unless you have a closed loop system. Do you have actual motion on your motors? That would be more of the tell on the Z axis.
Paul
« Reply #17 on: April 07, 2026, 04:28:51 AM »
How is logging done? Yes, when the coordinates move as seen in the video, the motors actually move when I jog. It's hard for me to record it all at once in one video because the screen is rotated differently and I can't record a clear video of the movement and the monitor. I'll send you a print screen of all the settings when I get to the plasma. Picture 05,06,07 are the Smooth Stepper Screen settings, Picture 01,02,03,04 are the Mach 4 settings.
« Reply #18 on: April 07, 2026, 09:28:45 AM »
Logging is done by going to Diagnostic → Logging. If you hit the gearbox once the window opens, you should be able to select the Log Categories. Just select all the checkboxes and hit play. This will start recording what happens in Mach.
So only when you directly jog the axis, motor Z moves, if you use your THC, Z does not move.. Is that understanding correct?
Paul
« Reply #19 on: April 07, 2026, 02:29:32 PM »
Yes, when I directly jog the axis, motor Z moves, if i use  THC, Z does not move.
