Hello Guest it is October 28, 2026, 08:47:56 AM
Author Topic: Basic pendant brains  (Read 166149 times)
0 Members and 5 Guests are viewing this topic.
« on: January 10, 2026, 07:17:46 AM »
I added a parallel port pendant to my Mach 3 controlled mill some years ago.  It has rotary switch selectors for axis and movement increment, with mpg and estop.  There is a button on the side to "load the settings".
The brains are pretty straightforward, NoOp-ing the selection lines.  Another brain uses the rotary switch outputs combined with the side button to "implement" the settings - invoking "JogOn."   So, you have to first set the rotary switches, then press the side button.
Is there a better way to do this?  I would like it to be ready to go immediately after setting the axis and increment.
Offline ZASto
  •  434 434
Re: Basic pendant brains
« Reply #1 on: January 11, 2026, 11:25:12 AM »
I stopped using Mach3 some years ago but, nevertheless, find attached brains that I used on one machine with 2 LPT ports
My personality is who I am.
« Reply #2 on: January 11, 2026, 12:22:43 PM »
Thanks.  I'll look at it.  I'm still using Mach 3 and parallel ports - because it works fine.   I use a 16 year old Win XP machine with solid state hard drive, not connected to a network.  Vectric Vcarve is on it too.  If it ain't broke ...
I gather that Mach 4 wants a newer machine.
« Reply #3 on: April 24, 2026, 10:40:20 AM »
hi
have you ever considered going down the modbus/arduino route. I have recently developed a control station setup using this and it seems to work fine. currently testing it on machine now. If your interested i could send you some details.
regards
servomac
