Hello Guest it is October 24, 2026, 08:43:43 PM
Author Topic: Centroid KP-1 Probe ESS C82 board Mach4  (Read 4486 times)
« on: January 01, 2026, 10:28:31 PM »
bought a Centroid KP-1 touch probe, Mach 4 not detecting probe trip.  Using ESS and C82 board with Machh4.  White wire from probe to Port 2 pin 9, active low, Black wire to Common. Green wire to ground and red to +24 volts DC. I hooked a volt ohm meter from pin 9 to common and the meter indicates pin goes to common when probe tripped. Probe goes from Greed LED to Red when tripped and verified with meter.  Mach shows no change of state. Diagnostic Page probe LED does not change. Probe enabled set to port 2 pin 9 active low. selected probe 0 in Mach4.  Any help would be great.
Re: Centroid KP-1 Probe ESS C82 board Mach4
« Reply #1 on: January 02, 2026, 05:15:58 AM »
From what you are saying, I see that you are connecting this to the terminals of the C82.  Keep in mind that the inputs of the C82 use bidirectional optos that work from +5vdc to +24vdc.  Maybe you are not wiring the correct common for the signals.  I think that the output of the centroid probe is equivalent to an NPN, and this wiring diagram may help:
https://www.cnc4pc.com/knowledge/article/195
You can also open a ticket in our website and send pictures of your wiring and we will give you a hand with this: https://www.cnc4pc.com/helpdesk/customer-care-4?contact_form=1
Arturo Duncan
https://cnc4pc.com
« Reply #2 on: January 05, 2026, 03:34:10 PM »
Thanks to the suggestions from Arturio Duncan. I figured out my mistake.  I did not have any voltage on the common on Port.  Here is what I ended up doing to get the Centroid KP-1 probe going.  Black wire to Ground from the power supply.  White wire to port 2 pin 9, then 5 volts to common on port 2.  Thanks for the assistance.
Mike B
