Hello Guest it is October 30, 2026, 11:14:46 AM
Author Topic: Spindle trips limit switch on every Gcode start  (Read 8244 times)
« on: December 19, 2025, 03:37:46 PM »
I'm trying to get my machine up and running again after replacing the computer.  I have it mostly set but still have an issue.
Every time I try to run G-code, the spindle moves up (in the Z-axis direction) until it hits the limit switch and then it stops.  There is no code in my G-code telling it to do that so it must be a machine configuration setting, but I don't know what setting needs to be changed.  Any help?
Allen
Allen
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Spindle trips limit switch on every Gcode start
« Reply #1 on: December 19, 2025, 08:53:08 PM »
Turn off safe Z move and make sure your initialisation string is something like "G20/G21" inch/metric plus " G40 G00 G90 G99 G43 G80 G54"
 This should be a safe start.
