Hello Guest it is October 30, 2026, 08:05:33 AM
Author Topic: Motion controller with analogue outputs  (Read 9153 times)
« on: December 10, 2025, 03:38:01 AM »
Hi Guys, I have an early Bridgeport Interact CNC milling machine, I converted it many years ago to use MACH3 and was working really well. I have been using the CS LABS IP/A motion controller. This stopped working so I sent it back to Poland to be inspected. They confirmed the device was faulty. After paying out large sums of cash, I received the repaired device back only to have the same fault. Now CS Labs support are no longer getting back to me.
What other motion controllers can I use. My Servo drives use a 10v signal, and I only need 3 axis.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Motion controller with analogue outputs
« Reply #1 on: December 19, 2025, 09:01:17 PM »
A lot of drives have both 10-0-10 volt input called analogue and also TTL step and direction input you need to find or check the manual for the drives you have.
If the drives can take TTL(0-5V) then any mach3 breakout board can drive the machine.
Sometimes you need to tell the drive the input type but some detect is automatically.
« Reply #2 on: December 20, 2025, 05:37:26 AM »
Have a look at CNC drive motion controllers. I have the uc100 and the eth400 and have not had issues with either. you can use the uccnc software or there  is a plugin for mach3. you can ask questions on the forum to make sure it will do what you want.
Regards
Charlie M.
« Reply #3 on: December 20, 2025, 05:51:39 AM »
Are these the old DC Servos?  Nowadays, it is just better to go with AC servos or closed-loop Steppers.  Those motors are high-maintenance and probably old, with a lot of wear.  Get something that is brushless, uses new technology, and is easy to connect to.
Arturo Duncan
https://cnc4pc.com
