Hello Guest it is November 13, 2026, 09:51:57 AM
Author Topic: Mach 3 Upgrade  (Read 9274 times)
Mach 3 Upgrade
« on: November 25, 2025, 02:34:22 PM »
I have an ancient system running Mach 3 on a Windows 7 pc through parallel ports to a motion control card driving servos.  I want to change the hardware to a USB interface motion controller card.  I'll get a new laptop and run Mach 3.  What are the recommendations for a motion controller card and BOB?
  •  9,377 9,377
Re: Mach 3 Upgrade
« Reply #1 on: November 26, 2025, 02:33:50 AM »
Perhaps the easiest (and cheapest) solution would be to use a CncDrive UC100.
Re: Mach 3 Upgrade
« Reply #2 on: November 27, 2025, 04:42:57 AM »
The UC400ETH is just a little more, and it is Ethernet. So much more reliable:
- Not sharing the grounds between the PC and CNC.
- Client-Server connection instead of running as a device on Windows.
- No significant cost difference.
Or even better, go with the Ethernet Smooth Stepper, which is fully compatible with Mach4 so that you can upgrade when you need to.
Arturo Duncan
https://cnc4pc.com
« Last Edit: December 01, 2025, 12:09:11 AM by Tweakie.CNC »
