Hello Guest it is November 13, 2026, 09:44:54 AM
Author Topic: Probing and tool change macros  (Read 9849 times)
« on: November 20, 2025, 05:21:09 AM »
Hi All,
Just new here, I have an old round column mill, 3d touch probe and tool setter. I am struggling to find a macro to probe z of part then reference the tool setter height then touch off tool setter with cutting tool and calculate tool length. I have tried my hardest with AI generated codes but no success.
Please....
Re: Probing and tool change macros
« Reply #1 on: December 03, 2025, 10:19:44 PM »
I wonder what control system you're using? Fanuc 0i / 16i / 18i / 21i?
« Reply #2 on: December 04, 2025, 05:08:45 AM »
I am using Mach3 with the generic red break-out board
« Last Edit: December 04, 2025, 05:12:12 AM by Geoffcncmilling »
« Reply #3 on: December 08, 2025, 01:07:14 AM »
Assume table surface is z zero. Use stylus probe to find the surface.  Then probe the top surface of the work.  Difference of the two readings is the height of the work above table, call it H.  Then mount tool and height setter and probe the top of the setter which should have a known height, say S. Now the tool is S - H above the work. Unless you can set each tool precisely in the spindle you have to repeat the tool height setting at each tool change.
Does that help?
