Hello Guest it is November 13, 2026, 02:13:43 PM
Author Topic: Mach3 Edit G Code  (Read 9257 times)
Mach3 Edit G Code
« on: November 11, 2025, 10:50:41 AM »
Has the capability for renumbering line numbers in Mach3 "Edit G Code" been removed as it used to work just fine?
Re: Mach3 Edit G Code
« Reply #1 on: November 14, 2025, 09:17:17 PM »
Nothing has changed kin M3 for over 10 years. The gcode editor isn't part of mach, it just calls up a Winows text editor which is where your problem may be. What win version are you using?
« Reply #2 on: November 15, 2025, 08:32:12 AM »
Windows 11
« Reply #3 on: November 15, 2025, 09:54:34 AM »
If you select config/general config on the menu bar, there is a control near the top centre where the text editor is selected.  Mine is set to Notepad - what is yours?  Notepad (a windows app) doesn't have an autonumber option but there are others that do.  Notepad++ might do it.  Google is your friend.
Why do you want to number lines?
