Hello Guest it is October 24, 2026, 08:47:16 PM
Author Topic: Mach4 probing script  (Read 5107 times)
« on: November 10, 2025, 05:25:23 PM »
Lua: Error while running chunk
C:\Mach4Industrial\ScreenScript.lua:1380: attempt to index a nil value (global 'prb')
stack traceback:
   C:\Mach4Industrial\ScreenScript.lua:1380: in function 'btnSurfXHelp_Clicked_Script'
No error's when loading. just when you attempt to ask for help.
and if you attempt to probe
ESS: Mach4 Enabled
ERROR: Invalid probing G code
Colten Edwards
www.lasernthings.ca
Re: Mach4 probing script
« Reply #1 on: November 12, 2025, 02:28:57 PM »
If I add the proper setup to the button's for help which involves loading the script since it's a separate instance, I  can see the help for about a millisecond. As the OK button is not respected.
McTouchOff provides some error messages as well. For some reason the file is not found in the modules directory. Once I moved it to a directory it was looking at, all is good.
Colten Edwards
www.lasernthings.ca
