Hello Guest it is October 25, 2026, 01:56:59 AM
Author Topic: Probe/Touch Off Error  (Read 5370 times)
« on: November 01, 2025, 12:49:50 PM »
Recenlty I've been getting an error when I run the Touch Off UI the second time. It works the first time and after probing Z, I run my program. Then I change the bit and run the Touch Off UI again, but it does not load. I see this error in the UI:
Lua: Error while running chunk
Viewing the log, I see this:
C:\Mach4Hobby\ScreenScript.lua:925: attempt to index a userdata value (global 'Iframe')
stack traceback:
   C:\Mach4Hobby\ScreenScript.lua:925: in function 'btnTouch_Left_Up_Script'
This is the Lua code referenced:
Code: [Select]
function btnTouch_Left_Up_Script(...)
    --Touch Button script
    if (Iframe == nil) then
    --TouchOff module
    package.loaded.mcTouchOff = nil
    mcTouchOff = require "mcTouchOff"
    Iframe = mcTouchOff.Dialog()
    else
    Iframe:ShowMenu()
    Iframe:Raise()
    end
I've not made any changes to the screen, modules, or anything else that I'm aware of recently  Short of reinstalling Mach 4 and having to reconfigure everything. Any input on why I'm seeing this?  I've run it as Administrator and not as Administrator and get the same error and issue. Running on Windows 11.
Re: Probe/Touch Off Error
« Reply #1 on: November 07, 2025, 06:18:44 PM »
Turns out it was, you guessed it, USER ERROR.  I had copied what I thought was an unmodified script from another, older screen set.  The issue was that "Iframe" should be "Tframe". Once that was corrected throughout the script, it now works correctly.
