Hello Guest it is November 18, 2026, 11:29:46 AM
Author Topic: Need some help with the inital setup  (Read 261824 times)
0 Members and 5 Guests are viewing this topic.
« on: October 26, 2025, 03:46:05 AM »
Hello,
i have some trouble with the inital setup of my modus setup.
I want to connect an Arduino Uno to my mach3 via modbus to instal some external periphery.
- the mist sprayer and the pump
- feed override and start/stop
In my fist setup I only want to switch the LED (PIN13) on the UNO on and off using M7 and M9.
I write the Arduino code:
Code: [Select]
#include <ModbusRtu.h>
#define LED1_PIN 13    // Ausgang 1 (z. B. Luft)
#define LED2_PIN 12    // Ausgang 2 (z. B. Flüssigkeit)
Modbus slave(1, Serial, 0);   // Slave-ID 1
uint16_t au16data[2];         // Zwei Register: 0 und 1
void setup() {
  pinMode(LED1_PIN, OUTPUT);
  pinMode(LED2_PIN, OUTPUT);
  digitalWrite(LED1_PIN, LOW);
  digitalWrite(LED2_PIN, LOW);
  Serial.begin(115200);
  slave.begin(115200);
void loop() {
  slave.poll(au16data, 2);   // 2 Register abfragen
  // LED 1 steuern
  digitalWrite(LED1_PIN, au16data[0] ? HIGH : LOW);
  // LED 2 steuern
  digitalWrite(LED2_PIN, au16data[1] ? HIGH : LOW);
I can test this with the Test Modbus.
If I read the holding register I get back an 0000. If I write 0001 to it, the LED goes on, if I write 0000 to the holding register the LED goes off.
The the UNO and the modbus is correct.
But now I can do what I want, I can not switch the LED on by M7.
I think there es some error, but I did not find it. Please help my.
My M7
Code: [Select]
SetModOutput(0, 1)
And the ModBusConfigration Screen
Re: Need some help with the inital setup
« Reply #1 on: October 26, 2025, 03:50:51 AM »
« Reply #2 on: October 26, 2025, 03:54:31 AM »
  •  9,377 9,377
« Reply #3 on: January 22, 2026, 01:54:02 AM »
Those who continue to use a ‘Pirate’ Mach3 license will not receive support on this forum.
This thread refers;  https://www.machsupport.com/forum/index.php?topic=24331.0
