Hello Guest it is October 24, 2026, 12:45:35 PM
Author Topic: mach 3 on windows7 platform  (Read 5586 times)
« on: October 25, 2025, 08:11:18 AM »
hi to you all,
i hope you guys help me on the problem i am having with my CNC router
here is the problem , when i am machining sharp outer corners machine rounds of the corners related to feed speed , what i mean by that is ,faster i cut bigger the radius is, if i go slow than it cuts as it should, i tried to tune the Servo motors on tune page under config tab but no hope. if i give to much acceleration on either side of the profile machine gets too jumpy
problem some what rectifies though, on the other hand if i set more smooth acceleration problem gets worse.
help will be greatly appreciated
Offline TPS
  •  2,627 2,627
Re: mach 3 on windows7 platform
« Reply #1 on: October 26, 2025, 08:49:16 AM »
maybe CV mode is turned on
