Hello Guest it is November 13, 2026, 09:51:15 AM
Author Topic: mach 3 on windows7 platform  (Read 8516 times)
« on: October 25, 2025, 07:52:58 AM »
hi to you all,
i hope you guys help me on the problem i am having with my CNC router
here is the problem , when i am machining sharp outer corners machine rounds of the corners related to feed speed , what i mean by that is ,faster i cut bigger the radius is, if i go slow than it cuts as it should, i tried to tune the Servo motors on tune page under config tab but no hope. if i give to much acceleration on either side of the profile machine gets too jumpy
problem some what rectifies though, on the other hand if i set more smooth acceleration problem gets worse.
help will be greatly appreciated
