Hello Guest it is November 13, 2026, 09:43:22 AM
Author Topic: Help required on Converting a RichAuto A51 controlled 3 axis router to Mach3  (Read 11116 times)
I inherited a 3 axis CNC router that was originally controlled via a RichAuto A51 hand held control that has failed for the 3rd time.
So, I hope to be able to replace the original control with a PC and Mach3.
I already own a small machine that I produce parts on using Mach3 that is installed on a desktop WinXP machine.
I am conversant with G code programming, tooling etc., but my expertise is almost non existent when it comes to building a control 'from scratch'.
Has anyone the necessary information on how to complete the modification or could perhaps provide me with the necessary links to sources that provide the information?
I have sufficient resources at hand to perform the electrical connections and I'm happy to purchase the details if required.
Many thanks in anticipation of any replies and assistance.
Check out this wiring diagram for upgrading a Richauto to an Ethernet Smooth Stepper with a C25XP:https://www.cnc4pc.com/blog/post-4/upgrade-richauto-to-a-c25xp-66
Thankyou very much.
Thanks, Arturo. That’s really helpful.
Quick question — can I reuse the existing stepper drivers with the ESS/C25XP setup, or do they need replacing?
Yes, it is just a matter of replacing the motion controller.  All the components remain the same.
Note that you will have to change the configuration in the VFD to take the variable speed, as the richauto does not handle variable speed, but just a set of fixed speeds.
If you need a hand with this, you can open a ticket in our website and we will help you: https://www.cnc4pc.com/contact
Arturo Duncan
https://cnc4pc.com
