Hello Guest it is November 13, 2026, 12:14:24 PM
Author Topic: Mach3 mist sprayer (stepper) external controller  (Read 9656 times)
« on: October 21, 2025, 02:08:00 AM »
Hello everyone,
today i have a mist sprayer with an Stepper and Air contolled by an arduino.
Now i am thinking off implement this into Mach3.
I don't want to change my wiring and setup in the machine, i am thinking of an standalone system only connect to mach3 via an modern interface.
My questions:
Is this possible?
Can i use an arduino for this? If so, what interface and protocol is possible?
Thank you for your help.
Have a nice day
Martin
  •  9,377 9,377
Re: Mach3 mist sprayer (stepper) external controller
« Reply #1 on: October 21, 2025, 03:02:33 AM »
Hi Martin,
Yes it is possible.
I have used a Chinese HID Relay board to switch a vacuum pump and an extractor via USB with no connections to the actual CNC machine. I works great.
This thread refers; https://www.machsupport.com/forum/index.php?topic=42968.msg278574#msg278574
« Reply #2 on: October 21, 2025, 05:20:30 AM »
Very interesting device and application.  We have a similar one: https://www.cnc4pc.com/shop/c92-c-modbus-server-4753
Sometimes it can be a little scary hooking up relays to a PC that are driven by software only, so we added an external enable input that can be hooked up to the enable line of the system.
Arturo Duncan
https://cnc4pc.com
« Reply #3 on: October 24, 2025, 03:48:18 AM »
Hello,
thank you, this sounds very good.
Question: the Arduino is connect to the PC with USB but is shown as COM5.
Can I setup an Skript like this:
M7.m1s
Code: [Select]
Dim Arduino
Set Arduino = CreateObject("Scripting.FileSystemObject")
Set Port = Arduino.CreateTextFile("COM5:", True)
Port.WriteLine "ON"
Port.Close
And send information to the Arduino without using the Modbus?
Have a nice day
Martin
