Hello Guest it is November 13, 2026, 04:39:50 PM
Author Topic: Tangential Cut  (Read 13765 times)
Tangential Cut
« on: September 29, 2025, 05:27:15 PM »
I need to setup MACH 4 for tangential cut.
Does MACH 4 for Hobbyist version include this option?
 Thank You,
EQ
Re: Tangential Cut
« Reply #1 on: September 29, 2025, 08:18:01 PM »
Yes, tangential is supported in Mach 4.
Go to the screen for:  Configure > Control  and select the Defaults tab.
Then look down the left side of the screen, the second block is a setting for "Control Mode".
In the drop down list for Control Mode you will find the option for Tangential.
Steve Stallings
www.PMDX.com
