Hello Guest it is November 13, 2026, 12:15:38 PM
Author Topic: Z issues and Gremlins  (Read 27941 times)
« on: September 16, 2025, 01:23:36 PM »
Hello all, new to forum so apologies in advance for anything out of sorts.
When conducting a pocketing operation with a .25 endmill the machine changed depths (.015 to 0.25) on its own whilst still displaying set depth (.015). I doubled checked the setup software (aspire 9.519) with nothing being off, I then flipped the material to side b, ran the same program/same setup, same X/Y/Z, and same endmill and it came out flawless.
New material, same program & setup and same error occurred, depth error whilst display did not change.
New material, all new program (aspire), same error occurred yet on a different toolpath (profile cut) and different endmill (.125).
Owner said it was salvageable so flipped to side B, same program. After selecting G code and program start, gantry moved from set X/Y to X-2" (on its own) and proceeded to cut the program and ruin the material.
Auto-Z has been off-broken-disabled for a while (previous cnc tech) so I have been doing it by hand/eye/flashlight but this error occurs after initial Z has been set and locked into Mach-3
Re: Z issues and Gremlins
« Reply #1 on: October 06, 2025, 10:49:02 PM »
Based on your description, the problems are almost certainly not with the Aspire software or the G-code itself, as the program ran perfectly on the "B side" before. All of the problems—unexpected depth changes, sudden X-axis shifts, and depth display errors—point to serious configuration errors or electrical faults in your Mach3 controller setup. Purchasing a Mach3 license will not fix these configuration or hardware issues.
