Hello Guest it is November 13, 2026, 09:37:55 AM
Author Topic: Mach 3 / ESS Smooth stepper / 2010 Screenset - homing issue?  (Read 32611 times)
« on: September 13, 2025, 10:22:39 AM »
Just finished installing ESS Smoothstepper and I'm having a problem getting Mach 3 to "Home" with the 2010 Screenset. Machine will home correctly when using the 1024 Screenset...  so it's like all of the homing options are dead on the 2010 screenset, anyone have any suggestions???
Hoping someone has run into this before...
Adam_m,
  •  9,377 9,377
Re: Mach 3 / ESS Smooth stepper / 2010 Screenset - homing issue?
« Reply #1 on: September 14, 2025, 01:21:00 AM »
Sounds like you have not installed the macro's ?
The 2010 manual is here;  http://www.thecncwoodworker.com/downloads/mach3/2010%20Manual.pdf
« Reply #2 on: September 14, 2025, 08:03:22 AM »
Spot on!!!
Many thanks... it had been so long since I initially installed the screenset I forgot there were setup instructions.
Happy CNC'ing!
Adam_M,
