Hello Guest it is November 22, 2026, 02:25:21 PM
Author Topic: Text engraving on a wheel  (Read 10224 times)
« on: November 22, 2007, 09:25:10 AM »
Is there any way to use Lcam to generate Gcode for engraving texts on a wheel (rings, counters). I have a four-axis CNC mill running Mach3. Thanks for response, Xavier
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Text engraving on a wheel
« Reply #1 on: November 22, 2007, 09:46:07 AM »
If you draw a rectangular box the length of the circumference of your ring/counter in the y axis and fit your text into it.
Then configure your A axis so that it is linear, work the steps out for 1" or 1mm of arc at the circumference of the ring.
Post out the code and change all the Y axis moves to A.
Run the program at your own risk.
Or
Use a CAM system.
Graham.
« Reply #2 on: November 22, 2007, 10:06:24 AM »
Great, I understand and will try it. have a nice thanksgiving day!
  •  2,785 2,785
« Reply #3 on: November 22, 2007, 10:29:08 AM »
Let me know how you get on,  :)
Graham.
