Hello Guest it is November 13, 2026, 05:30:57 PM
Author Topic: Mach4 – Z Axis Limit Switch Not Triggering During Homing Cycle  (Read 86049 times)
« on: September 05, 2025, 10:39:42 PM »
Hi everyone,
I’m currently facing an issue with my Z-axis homing routine in Mach4 and was hoping someone here might have some insight.
The setup:
Controller: Pokeys57CNC
Mach4 (latest build)
Limit/Home switches wired normally-closed
Diagnostics window shows inputs changing correctly when switches are pressed
Here’s the problem:
When I run a homing sequence, the Z-axis starts to move upward but never stops at the Z home switch. The diagnostic panel shows the switch toggling, but Mach4 doesn’t seem to register it as a “home” event. Instead, the axis just keeps moving until it faults out as if no switch was ever triggered.
What I’ve tried so far:
Swapping the Z switch with the X-axis switch → the physical switch works fine as an X home.
Checking input assignments in the Mach4 control configuration → they appear correct.
Verified with the Pokeys plugin diagnostics → Z switch activation is detected.
Tried reversing homing direction → no change.
So, the hardware and wiring seem fine, but Mach4 isn’t treating the Z home input as a valid homing signal.
Has anyone run into something similar with Mach4 not linking the home input to the actual homing routine? Could it be a signal mapping issue inside the plugin or something I’m missing in the homing/limits configuration?
Any advice, suggestions, or troubleshooting steps would be greatly appreciated!
Thanks in advance.
Re: Mach4 – Z Axis Limit Switch Not Triggering During Homing Cycle
« Reply #1 on: September 08, 2025, 07:58:40 AM »
I do not use Pokeys, I use the HiCon.  I have had this issue happen once before; my homing inputs were plugged into my plc and communicating with Mach4 over modbus.
For the HiCon, the homing and probing inputs MUST be plugged into the hicon itself.
I don't know how you have yours inputs physically mapped, but for me that was my issue.
Chad Byrd
« Reply #2 on: September 16, 2025, 11:30:47 PM »
I had that happen today when setting up my Pokeys57cnc on Mach 4
It went right thru the Z upper limit switch.  It was due to the pokeys plug in settings.  Let me know if you’re still having the issue.
