Hello Guest it is November 13, 2026, 03:01:39 PM
Author Topic: Triggering my plasma using a relay issues  (Read 58647 times)
« on: September 02, 2025, 01:02:58 PM »
Hello,
I have built a CNC Plasma Table with Mach3 USB as the controller.
I Have all 3 axis motors working, calibrated, and soft Limits set. It all works good.
My issue is triggering my Plasma torch.
I have a relay wired in. and I can send manual power to it and the Touch will fire.
In Mach3 I can hit the torch button, and m3 on, m5 off, and it will flash, and in the diagnostics page
it flash also.
I have the output pin port 1 and pin 1. On Router page, I have clock wise rotation to pin 1
I have the router relay turned off.
Mill page, I have the THC button on. (i have tried it both ways)
I have watched, read. All that I can find on the internet on wiring and trouble shooting the plasma switch trigger.
I have gone as far as uninstalling and reinstalling Mach3 software, and replacing the Mach3 board and the relay.
  I have since confirmed signal on #1 output pin and at the relay.  but the torch will not fire. again I have taken the trigger 2 wires and connected them and the torch will fire.
 I have replace the relays.
 Am I missing a button or function ?
  would there a good guide on setting up Mach3 for a plasma cutter?
  I am sending screen shoots of a few pages in Mach3 program!
  THANKS for any help or directions!!
  JDEWizard
  •  9,377 9,377
Re: Triggering my plasma using a relay issues
« Reply #1 on: September 02, 2025, 10:48:21 PM »
What is the make and model of your Mach3 USB controller ?
« Reply #2 on: September 03, 2025, 02:46:14 AM »
4 Axis Red USB Port Mach3 Motion Control Board.
 (bsmceo4u-pp)      is on the board
JDEWizard
« Reply #3 on: September 04, 2025, 08:51:41 AM »
That motion controller does not support THC or other real-time motion control features.  Upgrade to a UC100 or Ethernet Smooth Stepper or other good motion controller.
Arturo Duncan
https://cnc4pc.com
« Reply #4 on: September 04, 2025, 10:28:59 AM »
Thanks for the  relay.
 question
 what i am trying to do is to just turn the torch on with the controller with out having the THC.
so this is not possible with this controller?
JDEWizard
