Hello Guest it is November 13, 2026, 02:17:56 PM
Author Topic: Mach 4 and fc300 VFD  (Read 182837 times)
Re: Mach 4 and fc300 VFD
« Reply #10 on: September 10, 2025, 11:45:44 AM »
Please open a ticket in our website and someone with check the manual for you on advise on setting it:
https://www.cnc4pc.com/contact
If you have a link to the manual, please send it.
« Reply #12 on: September 11, 2025, 08:19:02 PM »
good old-fashioned Chinglish!
Chinese VFD's are cheap, but thats about all they have going for them.
I use Delta VFDs (a Taiwanese brand made in China) for twenty years, both on my own equipment and for customers. Never had a failure and vastly better documentation
and set-up software.
« Reply #13 on: October 08, 2025, 04:00:20 PM »
ya I ended up just getting another VFD, and from that it works great. I can go reverse now with the commands, only issue is on Mach 4 the spindle default minimum speed says 8000rpm, If i use M3 S1000 or such it wont go below 8000 even clicking the override, goes up no problem.
Everything is properly set to min rpm as 0, is there a setting somewhere I'm missing. This is all to setup the rapid change atc.
« Reply #14 on: October 10, 2025, 11:11:33 AM »
I did find this while searching through the files in the profile folder, is this what I needed to change and if so where could I access the settings for this part?
here is a picture. DefaultMinSpindleRPM  0 and 8000 or 1000
