Hello Guest it is November 13, 2026, 07:13:27 PM
Author Topic: probe gcode for MDI  (Read 72119 times)
probe gcode for MDI
« on: August 27, 2025, 06:04:22 AM »
Hi I am having trouble wrtting a Gcode to set the Z axis in the MDI  I feed down and set it using a G92  but then when resetting Z latter on its currupted
This works sort of
G90
G49
G91
G31 Z-1.0 F4
G90
#5223 = -3.85
G91 G0 Z0.1
G90
G43 H1
But the height is 1.866  but have to add 1.984  to it to get it to read right and set the Z axis and have no idea why
What I want it to be able to set a tool using the probe to 1.866 the height of my setting block  but what ever tool I use  and they mostly have offsets so a H3 for tool 3 need to be in the mix
The probing built in to mach4 sets only when there is a zero offset t
