Hello Guest it is November 13, 2026, 10:42:56 AM
Author Topic: 2 spindel axes Mini swiss Lathe  (Read 35552 times)
« on: August 22, 2025, 10:40:47 AM »
Has anyone already driven two spindle axes at different speeds, where one axis, the C axis, can also be set in degrees? It is for a small Swiss-type lathe project. I would like to use the 6-axis controller from CS Labs for this. I would like to use this on Mach 4.
Offline TPS
  •  2,627 2,627
Re: 2 spindel axes Mini swiss Lathe
« Reply #1 on: August 25, 2025, 08:09:01 AM »
i  am running two spindles on oene of my machines with a IP-S controler.
main spindle in step/dir mode controled via M3/M4/M5
second spindle controled via analog and digital outputs via self written M33/M34/M35 macro's.
only thing is, i am using Mach3 and VB-Script.
no clue with Mach4 and how "good" CS-Lab Mach4 pluging works.
