Hello Guest it is November 13, 2026, 09:47:27 AM
Author Topic: Mil on acryic  (Read 17921 times)
Offline jacques_w
  •  6 6
  • Hai volks
Mil on acryic
« on: August 11, 2025, 10:11:40 AM »
I want to mill acrylic from now on. Question: What speed (F) should I use and how much rotation (S) should I use?
Please answer.
none
Offline rcaffin
  •  1,073 1,073
Re: Mil on acryic
« Reply #1 on: August 13, 2025, 05:48:44 PM »
If you spin too fast the acrylic will melt. Feed can be as fast as you want, subject to breaking cutters.
Really strongly recommended is to use some lubricant - not 'flood cooling', just a little lube, so the cutter does not drag. I use a mix of 3 parts kero to 1 part olive oil (skin friendly), but straight kero or even water might work. Check out "MQL" as well.
Roger
