Hello Guest it is November 13, 2026, 07:53:09 PM
Author Topic: Possible to use M3 to start plasma and use M63 or M65 to turn torch off?  (Read 45955 times)
Hello, I'm having trouble with using M63 (with G1 movement following it) to turn off spindle (plasma torch). I'm using Mach4 hobby licensed.
I have CSMIO IP-M motion controller which unfortunately doesn't let me set the digital output pin to both Spindle FWD AND Output#1 for example.
I would like to use M3 to start since it has all the built-in probing etc. working nicely, but it would be great if I could turn the torch off fast during lead out move with M63 so cuts would be smoother.
I think it's not possible to script M63 to turn off spindle. Any ideas?
Some stock M Codes can be modified and some can not.  For example, I always modify my M30 to do a number of tasks outside of the stock commands; I make sure those OEM commands back into the M30 macro I make.  But the M63 (as far as I know) cannot be modified.  There was a list of m codes that can and cannot be modified and I cannot find them for some reason, I have looked; if I find them I'll post them here.
Chad Byrd
