Hello Guest it is November 13, 2026, 11:39:12 AM
Author Topic: Mach 3 Welder Setup and Rotary Question  (Read 46400 times)
Offline TPS
  •  2,627 2,627
Re: Mach 3 Welder Setup and Rotary Question
« Reply #20 on: July 17, 2025, 10:17:42 AM »
then you can use b-axis dir pin for example to switch weldin on without delay.
if you search for laser and dir pin you will find examples.
« Reply #21 on: July 17, 2025, 12:11:41 PM »
This sounds like it could work. Let me do some research on this and see what I can come up with.
