Hello Guest it is November 13, 2026, 01:37:29 PM
Author Topic: Mach 3 Welder Setup and Rotary Question  (Read 46405 times)
Offline TPS
  •  2,627 2,627
Re: Mach 3 Welder Setup and Rotary Question
« Reply #10 on: July 17, 2025, 05:58:14 AM »
the program you posted would look like this:
Code: [Select]
  N1 (USER 3)
  N2 G91
  N3 G0 A0.0
  N4 M8 (GAS ON)
  N5 G04 P1.5
  N6 M11 P1 (Start Weld)
  N7 G01 A-400.0 F1500.00 (ROTATIONAL SPEED)
  N8 A-60.0
  N9 M10 P1 (Stop Weld)
  N10 G04 P1.5 (DWELL FOR POST FLOW TIME)
  N11 G0 A520.0 X-0.400 (MOVE TO NEXT START POSTION)
  N12 M30
M11 P1 will turn ON Output1 and the next GCode line must be
a axis move
M10 P1 will turn OFF Output1
« Reply #11 on: July 17, 2025, 06:02:49 AM »
Code: [Select]
  N1 (USER 3)
  N2 G91
  N3 G0 A0.0
  N4 M8 (GAS ON)
  N5 G04 P1.5
  N8 A-60.0
  N12 M30
a axis move
So in the settings I just need to turn on Output 1? Will I have to switch any wires around on the control board to make this work?
Offline TPS
  •  2,627 2,627
« Reply #12 on: July 17, 2025, 06:04:34 AM »
you can use any Output witch is configured in Config -> Ports&Pins -> Outputs normaly,
depends a bit on the motion controller.
« Last Edit: July 17, 2025, 06:10:45 AM by TPS »
« Reply #13 on: July 17, 2025, 08:05:31 AM »
I do not think the controller is liking the M10/M11 codes. When I look up the M code list in the controller those are not listed. Is there a setting to turn those on? I searched google and the image that pops up I do not have the check box like what it is showing.
Offline TPS
  •  2,627 2,627
« Reply #14 on: July 17, 2025, 08:27:31 AM »
witch controller are you using?
« Reply #15 on: July 17, 2025, 08:42:49 AM »
Mach 3 USB interface board. Its the red one. I am not for sure in the differences of controllers.
Offline TPS
  •  2,627 2,627
« Reply #16 on: July 17, 2025, 08:46:27 AM »
if you talk from such:
https://buildyourcnc.com/products/electronicsandmotors-electronic-component-breakout-mach3-usb-board
a thing, i think we reached the end of the road for using M10/M11.
Offline TPS
  •  2,627 2,627
« Reply #17 on: July 17, 2025, 09:28:34 AM »
i assume you have all 4 axis intefaces of the board in use?
otherwise it would be possible to use thr dir output of an unused axis.
« Reply #18 on: July 17, 2025, 09:34:33 AM »
Yes this is the board that I am using. I could buy a different board and change stuff over.
« Reply #19 on: July 17, 2025, 09:35:01 AM »
I am only using two axis, the X axis and the A axis.
