Hello Guest it is October 20, 2026, 04:00:14 PM
Author Topic: Need help. Velox 5050 CNC router w MX4660 E-stop not resetting  (Read 16807 times)
Hi All,
I have searched and seen a few posts regarding this same issue, and wondering if there is a better way to diagnose a possible faulty MX4660 than buying a new one at $400.00. I have mach 3, but am not super great with it.
The issue:
Upon power up, the machine wont reset in mach 3. I checked the e-stop for continuity and it seems ok, have not checked voltages. I never use the e-stop so this error came out of nowhere.
I tried going into ports and pins and changing the active low, and that allows my machine to reset, but the drives won't power up. I can use the keyboard to move, and mach thinks it's moving; but there is no physical movement.
Any suggestions? Should I try to contact Leadshine support? Is there anything else that I can check other than the e-stop? My limit switches all look ok, I can check continuity pretty easy on them though and that's my next step.
I found a manual online I can try checking some voltages, I'm just not really sure where to start.
Any help is very much appreciated. If I do need to replace the MX4660, is there another option I should look at that is more robust? I have had a few timout type of errors when running long programs... where I end up having to restart the program from the beginning.
Picture 1 shows status on powerup.
Picture 2 shows mach on powerup.
Picture 3 shows status after mach boots up.
Picutre 4 shows mach after disabling active low.
Thank you!
Mark from Washington
  •  9,374 9,374
Re: Need help. Velox 5050 CNC router w MX4660 E-stop not resetting
« Reply #1 on: May 30, 2025, 05:55:10 AM »
Something very basic to check is that your physical EStop button has been reset (twisting knob to release it).
« Reply #2 on: May 30, 2025, 11:08:58 AM »
Yeah I have tried that. I have contuniuty and it seems to be working... I suppose I can start checking voltages..
