Hello
Guest
it is
October 11, 2026, 11:54:34 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
X Axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: X Axis (Read 6511 times)
vincent_savory
3
X Axis
on:
March 26, 2025, 09:51:24 PM »
I have not used my CNC for over seven months. It worked fine before; however, I recently powered it back up, and now the X-axis only moves in the negative direction, even when I press the right arrow key.
Logged
Sometimes it's better to apologize than to ask permission.
cncmagic
137
what me worry? heck...it ain't my machine anyway
Re: X Axis
Reply #1 on:
March 26, 2025, 11:14:51 PM »
then probably, for whatever reason, you have lost the 'direction' signal from your motion card to either your stepper or servo. The 'step' signal is ok since its moving. It only goes in one direction because the direction is either always active or always inactive depending on how everything is wired. I'd check the connections first. After that the best method at this point is simply use a VOM to check the status of the direction signal on the motion card. It should remain in whatever state the last command (+ or -) was. And you should post what your setup is also. Bob
Logged
any semblance of information posted to anything remotely close to accuracy is merely coincidence. Use at you own discretion.. or play the lottery.. same odds
Print
Pages:
1
Go Up
« previous
next »
