Hello Guest it is November 23, 2026, 03:10:21 AM
Author Topic: LABEL WITH TOOL DESCRIPTION  (Read 317465 times)
« on: February 28, 2025, 03:26:25 AM »
Hi everyone, is it possible to create a label on the computer screen and populate it with the description of the tool in use?
Offline TPS
  •  2,627 2,627
Re: LABEL WITH TOOL DESCRIPTION
« Reply #1 on: February 28, 2025, 04:50:37 AM »
not directly you can make a workarround via macropump macro
code for Userlabel 123 would be:
Code: [Select]
SetUserLabel(123, GetToolDesc(GetDRO(24)))
!not tested
« Reply #2 on: March 04, 2025, 11:40:25 AM »
thanks for the reply.
How do I apply this variable to the label in mach screen? I see that it is not possible to put functions in labels
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 04, 2025, 11:54:44 AM »
you have to make a userlabel in your screen, for example Userlabel123
and the code needs to be in macropump.m1s macro. make sure macropump is enabled in general config.
« Reply #4 on: March 04, 2025, 02:09:08 PM »
this way?
because i tried but it doesn't work...
Offline TPS
  •  2,627 2,627
« Reply #5 on: March 05, 2025, 12:14:56 AM »
yes this way.
for a quick test open Menu:
Operator -> VB Script Editor
then copy and paste this code into Editor
Code: [Select]
and use the green start button to run it
« Reply #6 on: March 05, 2025, 06:50:18 AM »
I tried to do as you say but the label doesn't change it stays like this
Am I doing something wrong?
Offline TPS
  •  2,627 2,627
« Reply #7 on: March 05, 2025, 11:05:43 AM »
not sure, but i think it needs to be UserLabel123 insteed of Userlabel123
made a quick test here and it works
« Reply #8 on: March 05, 2025, 11:58:39 AM »
but are you using machscreen?
I tried to insert the text but it doesn't work for me, it takes the instruction as text
Offline TPS
  •  2,627 2,627
« Reply #9 on: March 05, 2025, 12:04:11 PM »
