Hello Guest it is October 18, 2026, 06:44:37 PM
Author Topic: (Jog) speed during Probe wizard moves  (Read 7390 times)
« on: February 24, 2025, 02:01:12 PM »
All,
I’m trying to get my mill to run with Smoothstepper and mach3 for quite some time now.
Where I struggle is with using and obviously configuring probe wizard. When I start an x y measurement on the lower left corner, the mill moves dead slow until it reaches the start point of x measurement. Then it moves with search speed, probes, then latch speed, probes again. So all fine.
When the mill moves over to the second measuring position of y it’s dead slow again - obviously latch speed. Then it moves with search speed again, probes, then latch speed, probes again. So again all fine.
TS and workpiece height speed are ok.
If I now load gcode to do some work the toolchange is detected correctly and the mill starts to move to the tool change position - guess what - dead slow again.
From now on I can’t get back to the normal jog speed.
What am I doing wrong?
Help would be gladly appreciated
Stephan
Re: (Jog) speed during Probe wizard moves
« Reply #1 on: February 24, 2025, 04:13:07 PM »
Found it!
Feed rate was set incorrectly.
