Hello Guest it is October 20, 2026, 06:18:16 AM
Author Topic: z axis raises after feed hold restart  (Read 8786 times)
« on: February 10, 2025, 12:59:44 PM »
I have 3 machines, one of which runs Mach 4 (avid) and the other two (blue elephants) running mach 3. I have a marker operation on these machines that I drag sharpies across the material to draw on them. Occasionally they start to fade during the operation. If I hit FEED HOLD and change the marker, the Mach 4 machine simply continues the path. The other 2 Mach 3 machines will start the forward motion but raise the z axis at the same time until it rises about 1.94".  Any ideas as to what set this function? Is it controller, Mach settings?  I run the same Gcode for all machines.  I have to "run from here" on these machines where as just hit start again on the avid Mach 4.
Re: z axis raises after feed hold restart
« Reply #1 on: May 03, 2025, 07:32:27 PM »
It could be possible its a safe Z setting. Goto Config/Safe Z setup and see if there is something there to adjust.
Regards
Charlie M.
