Hello Guest it is October 18, 2026, 07:34:12 PM
Author Topic: Encoder de 1024 pulsos configurado como MPG  (Read 24972 times)
Re: Encoder de 1024 pulsos configurado como MPG
« Reply #10 on: February 19, 2025, 07:47:54 AM »
I took the time to make a video for you, explaining the problem so that you can better understand what is happening on my machine.
Thank you very much in advance, I leave you the YouTube link.
https://www.youtube.com/shorts/odg0tRoL1SA
« Reply #11 on: February 20, 2025, 03:00:41 AM »
I'm sorry but I'm not inclined to look at a video.  I have said before, it may be that the Z DRO is expecting 1000 pulses per MPG rev so each pulse would be one increment of say 5/1000 mm or 5 micron (assuming a 5mm pitch screw).  But one turn of your MPG would feed it 1024 pulses to the Z axis so the Z axis would actually move 1024x5=5.12mm.
« Reply #12 on: February 20, 2025, 11:16:12 AM »
Juan, no problem. If you had watched the video, you would realize that is not the problem. Although it is as you say, when the MPG shows 0, the axis should end at 0. For example, if the encoder makes 10 turns and returns 10 turns, the DRO of the axis should return to the initial point as drawn by the MPG.
Kind regars,
Fred
« Reply #13 on: February 24, 2025, 06:31:48 AM »
« Reply #14 on: February 28, 2025, 04:11:09 PM »
I leave another video so you can see progress
https://youtube.com/shorts/2xmCvPPHBDA?feature=share
