Hello Guest it is November 27, 2026, 11:17:34 PM
Author Topic: No Movement  (Read 550460 times)
0 Members and 4 Guests are viewing this topic.
No Movement
« on: January 20, 2025, 04:50:22 AM »
Hi Everyone,
I run a 3 axis router with Smoothstepper. Today the machine suddenly stopped running. Everything looks normal in Mach3. If I jog or turn the spindle on I see movement on the display but the machine doesn't respond. Could I have accidentally gone into some kind of simulation mode? Restarting the computer doen't change anything.
Thanks.
Re: No Movement
« Reply #1 on: January 20, 2025, 10:46:55 AM »
Sounds more like a hardware fault with the smooth stepper.  Possibly the power supply to the stepper drives?  Do you have a multimeter so you could check the voltage?
Re: No Movement
« Reply #2 on: January 20, 2025, 12:02:26 PM »
On the money! I decided to check the main power supply and it is putting out 0.5v. It's so nice when there is a simple solution.
Re: No Movement
« Reply #3 on: January 20, 2025, 12:41:54 PM »
Excellent.  Is that with everything disconnected?  If it's 0.5v connected but normal disconnected it could be a short circuit.
Re: No Movement
« Reply #4 on: January 20, 2025, 01:40:11 PM »
Thanks, I should check that. I already ordered a replacement on Ali which should come in a week.
Re: No Movement
« Reply #5 on: January 21, 2025, 03:42:24 AM »
I just checked. No load voltage is 20V. Operating voltage is supposed to be 48V, so it seems pretty certain that it's just a bad power supply.
Re: No Movement
« Reply #6 on: January 21, 2025, 03:44:15 AM »
Sounds like that's your problem then. Good luck with the new PSU.
