Hello
Guest
it is
October 20, 2026, 03:04:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
overshot X axis using Mach 3 software
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: overshot X axis using Mach 3 software (Read 13613 times)
jimthefish
309
on:
January 14, 2025, 05:02:49 AM »
Working in a very tight area and unfortunately pressed X+ instead of X- and over shot the limit switch. How do I get the machine to allow me to jog off, Cannot get the rest button to stop on, so cannot do any moves.?
Last Edit: January 14, 2025, 05:09:10 AM by jimthefish
Logged
JohnHaine
975
Re: overshot X axis using Mach 3 software
Reply #1 on:
January 14, 2025, 07:24:05 AM »
Go into config and disable the limit switch.
Logged
jimthefish
309
Reply #2 on:
January 14, 2025, 08:00:00 AM »
Cheers John, I've been using this machine for 25years and thought i would test it one last time before selling it and pressed x+, I put it down to my old age
Logged
JohnHaine
975
Reply #3 on:
January 14, 2025, 12:22:20 PM »
HTH Remember to re-enable it!
Logged
jimthefish
309
Reply #4 on:
January 15, 2025, 01:44:30 PM »
Done, Thanks mate
Logged
TPS
2,627
Reply #5 on:
January 16, 2025, 06:59:40 AM »
in Settings (Alt-6) screen is a button called
OverRide Limits
for this situation, it will allow you to jog off the limit switch and will be disabled
automatcly if the limit switch is free. so nothing to change in config and nothing
will be forgoten.
Logged
Print
Pages:
1
Go Up
« previous
next »
