Hello Guest it is October 12, 2026, 05:55:03 PM
Author Topic: read only DRO's  (Read 9654 times)
read only DRO's
« on: January 13, 2025, 08:39:07 AM »
I have a couple of DRO's which I don't want to change on screen. they are computed values which are stored in persistant register's. Options for DRO readouts are in place, keypad .... and Read ONLY.
The Read only option does nothing as far as I can tell. It  seems the user can edit that DRO and cause the calculated value to change. Am I misunderstanding the meaning of Read Only?
Colten Edwards
www.lasernthings.ca
Re: read only DRO's
« Reply #1 on: January 13, 2025, 09:18:01 AM »
Under the properties, uncheck the "Enabled" check box.  This will prohibit you from being able to alter the DRO manually.
Chad Byrd
Re: read only DRO's
« Reply #2 on: January 13, 2025, 11:10:18 AM »
Thank you. That's what I needed. Wonder what Read-Only is supposed todo then.
Colten Edwards
www.lasernthings.ca
Re: read only DRO's
« Reply #3 on: January 14, 2025, 01:30:34 PM »
I have no issues with the read only setting here…
