Hello Guest it is November 13, 2026, 03:47:47 PM
Author Topic: Run From Here  (Read 9627 times)
Run From Here
« on: November 20, 2007, 06:19:19 PM »
How exactly does the Run From Here button work in ToolPath view? I've tried it a couple of times but couldn't get the results I was expecting.
Re: Run From Here
« Reply #1 on: November 21, 2007, 06:09:09 AM »
You should be able to enter the line number you want to run from, hit run from here, cycle start. You should see a pop up saying mach wants to make a prep move. Accept the move, hit cycle start. It is assuming it has run the code to this point allready so if you were running a roughing pass in the code before the point you started at and you just skipped it by run from herre, that would make a mess.
Hope this helps some,
