Hello Guest it is October 12, 2026, 01:22:35 PM
Author Topic: Mach4/ESS spindle/idexed c axis setup  (Read 16899 times)
« on: January 02, 2025, 07:04:37 AM »
hello everyone. I'm having a lot of trouble finishing my project. as the title says, I work on Mach4 and ESS Smoothstepper. I managed to connect a servo motor to the spindle and now I have both the spindle and the indexed C axis on one motor. I am able to switch between them using a command
mc.mcAxisMapMotor
and it works perfectly. but the problem is that I need different motor settings (steps per unit, acceleration, etc.) for both. when I set the correct settings for the spindle, the C axis has the incorrect ones. Changing the engine parameters with a code
 mc.mcMotorSetCountsPerUnit
would solve the problem after the
 mc.mcAxisMapMotor
command but it only works once and you cannot return to the previous settings. I also cannot assign the same pins to 2 motors and assign them to specific axes interchangeably. then everyone would have their own settings and that would solve the problem
Offline smurph
  •  1,575 1,575
Re: Mach4/ESS spindle/idexed c axis setup
« Reply #1 on: January 08, 2025, 05:04:06 PM »
Simply save the spindle motor parameters first, say in the screen startup script.  mc.mcMotorGetCountsPerUnit(), etc...  Then you can do the mcAxisMapMotor() and mcMotorSetCountsPerUnit when you want to use C.  Then swap back to the spindle settings when you are done with C.
Steve
« Reply #2 on: January 08, 2025, 05:15:19 PM »
Steve
You're right. I tried this before. and it actually works, but only once when I change the steps per unit. another change is only possible after restarting the program.
Offline smurph
  •  1,575 1,575
« Reply #3 on: January 09, 2025, 01:06:45 AM »
If you change the counts per unit back they don't stick?  Are you running a step/direction controlled spindle?  And what do you mean by "pins" when you said "I also cannot assign the same pins to 2 motors and assign them to specific axes interchangeably. then everyone would have their own settings and that would solve the problem" ?
Do you have script examples?  What build of Mach?
Steve
« Reply #4 on: January 09, 2025, 02:54:36 AM »
Steve
I using AC servo moror as spindle.(Step/dir). It has 10000/rev encoder. When using as spindle everything is ok. Max rpm 3000 ( 1:1 pulleys). When using as CAxis must set 27.777 counts/rev. (10000/360°). I cant use electronic gear ratio in servo controller. I attach spindle motor as motor 5 with 10000counts/ rev settings as spindle motor, and motor 2 with 27.777 counts as C axis motor. To control them i cange motors by using m.mcAxisMapMotor command and mannualy assign output pins(step/dir signal) in ESS controller output tab to the specific motor. (Dont must restart mach4) When i change counts per unit by script it changing once and cant change back to the native settings. Until restart mach4. Mach4 ver 4809 and ess plugin 285. I want to change settings by using screen button settings. I know how to do this but i cant find solution to the motor settings.
« Reply #6 on: January 09, 2025, 06:09:58 AM »
You may want to check this setup:
https://www.cnc4pc.com/blog/post/mach4-lathe-using-the-ethernet-smooth-stepper-and-the-c82-breakout-board
https://www.cnc4pc.com/blog/post/configure-an-step-and-direction-servo-as-spindle-on-mach4-using-the-ethernet-smooth-stepper-and-c82
Arturo Duncan
https://cnc4pc.com
That is hardwate solution of this problem. Im looking for software solution. I hope that is any way to do this by using script. I dont want to rebuild driver and connections.
Offline smurph
  •  1,575 1,575
« Reply #7 on: January 14, 2025, 04:47:12 PM »
Steve
I'm trying to figure how you are driving your spindle with step/dir.  Are you setting the "Sep/Dir Spindle Axis" setting to OB1-OB6?
Steve
« Reply #8 on: January 14, 2025, 05:28:19 PM »
Steve
Steve
exactly. servo motor with 17-bit absolute encoder. connected and described as motor5 and assigned to the OB1 axis.
