Hello Guest it is September 03, 2026, 03:38:41 PM
Author Topic: 2 cnc boards  (Read 31948 times)
Offline p7m13
  •  18 18
2 cnc boards
« on: December 29, 2024, 09:42:17 AM »
I have 3 motors managed by a Chinese 4-axis board.
https://fr.aliexpress.com/item/32918200137.html?spm=a2g0o.productlist.main.15.31927a38hHL5zY&algo_pvid=2070012e-b8cf-4db4-b7dc-f20f27ffc20a&algo_exp_id=2070012e-b8cf-4db4-b7dc-f20f27ffc20a-7&pdp_npi=4%40dis%21EUR%216.61%216.59%21%21%216.72%216.70%21%40210390b817354862584254867e4333%2110000012811635421%21sea%21FR%211897906811%21X&curPageLogUid=hchAF7XenEek&utparam-url=scene%3Asearch%7Cquery_from%3A
Finding the right wiring diagram was particularly difficult.
The 3 engines run well with Mach3.
The only thing I notice is that, with identical adjustment parameters, the 3 motors run slower on x than on the other 3 axes: I wonder why ...
I would like to add 2 axes. Buying a Chinese FIVE-axis board will probably lead to the initial result : major cabling problems.
So I'm considering buying the same 4-axis "white eagle" board.
My question is: is it possible to run 2 occurrences of the program simultaneously ?
  •  9,368 9,368
Re: 2 cnc boards
« Reply #1 on: December 30, 2024, 12:22:05 AM »
No, that would not be possible.
Offline p7m13
  •  18 18
Re: 2 cnc boards
« Reply #2 on: December 30, 2024, 03:51:33 AM »
If I buy a new interface board from China, I'm afraid I'll have big wiring problems.
I think I'm going to stick with my 4-axis board and place several inverter switches to manage, from time to time, the fifth axis
Offline p7m13
  •  18 18
Re: 2 cnc boards
« Reply #3 on: December 31, 2024, 12:25:19 PM »
Another possibility: not to add inverters but to keep the current setup for XYZ and to add another Windows (which I have) for the toggle and rotation of my divider. I then have my 5 axes but I have to buy a second manual steering wheel.
What is the best ?
Re: 2 cnc boards
« Reply #4 on: December 31, 2024, 01:03:39 PM »
What do you mean by inverter?
Re: 2 cnc boards
« Reply #6 on: January 01, 2025, 01:44:34 AM »
Change-over switch
Re: 2 cnc boards
« Reply #7 on: January 01, 2025, 02:56:16 AM »
It would help if you could explain what you want to accomplish. Is it just to add a rotary axis? Why does that need 2 axes, what's the difference between toggle and rotation?
Offline p7m13
  •  18 18
Re: 2 cnc boards
« Reply #8 on: January 01, 2025, 10:18:01 AM »
https://fr.aliexpress.com/item/1005006353184440.html?spm=a2g0o.productlist.main.3.5d4dxCw7xCw7KM&algo_pvid=1f6f3413-9014-4a38-a3e6-dac442f48d6f&algo_exp_id=1f6f3413-9014-4a38-a3e6-dac442f48d6f-1&pdp_npi=4%40dis%21EUR%21207.47%21200.69%21%21%211542.53%211492.12%21%40210384cc17357478264454986ea5e7%2112000036863166808%21sea%21FR%211897906811%21X&curPageLogUid=3bC97Yaf8iBu&utparam-url=scene%3Asearch%7Cquery_from%3A
In France, this is called a divisor ... On this device that I will use FROM TIME TO TIME, 2 movements are possible: the rotation of the workpiece, the tilting of the support (mandrel or vice or flanges) of the workpiece. I want to make these 2 movements FROM TIME TO TIME thanks to 2 Nema34 8.5 Nm motors. For the tilting, I ordered a helical gear (which will bring an inaccuracy...). For the rocker, I ordered a ball screw with a diameter of 25 mm.
« Last Edit: January 01, 2025, 10:20:05 AM by p7m13 »
Offline p7m13
  •  18 18
Re: 2 cnc boards
« Reply #9 on: January 01, 2025, 10:21:06 AM »
Modify does not work.   Strange
For the tilting, not the rocker
