Hello Guest it is November 07, 2026, 10:40:00 AM
Author Topic: Using Lazycam to mill Printed Circuit Boards  (Read 10528 times)
« on: November 20, 2007, 01:22:50 PM »
Good Day to all. I am trying to use Lazycam to import GERBER (.GBR)  format PCB plot files and then to generate the isolation G-Code file to mill out the copper areas around the PCB tracks, using Mach3.  I cannot seem to get Lazycam do do what I think it should and cannot find any help topics on this subject.  I have tried very simple Gerber plot files to quite complex ones and the behaviour is similarly confusing. Any help would most kindly be appreciated.
Thanks.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Using Lazycam to mill Printed Circuit Boards
« Reply #1 on: November 20, 2007, 03:12:48 PM »
Hi, JoNo
Post your file use the Reply Button and Attach.
Thanks, Chip
« Reply #2 on: November 26, 2007, 04:25:14 PM »
I havent tryed milling a PCB, but I used the excellon drill import,  works great!
Jeff Davis
