Hello Guest it is October 21, 2026, 12:54:01 AM
Author Topic: Mach3 Auto Probe sometimes doesn't run until I jog the axis  (Read 14845 times)
« on: December 18, 2024, 10:48:57 AM »
Mach3 with an Omio cnc.
I have a probe script that works perfectly when it works, but it's 50/50 whether or not it will work or not. The behavior is the script runs the g31 command, and prints out a debug message that occurs _after_ the g31 command, but the motors don't move, and neither does the DRO.
Jogging the axis that I'm trying to probe a bit then lets me run the probe, but even this fix is only 90% effective.
Re: Mach3 Auto Probe sometimes doesn't run until I jog the axis
« Reply #1 on: December 18, 2024, 11:25:57 AM »
Code please?
« Reply #2 on: December 18, 2024, 11:33:12 AM »
Here's one of them. All do the same thing, just different axes
« Reply #3 on: December 18, 2024, 12:34:44 PM »
Amazingly complex for a simple function.  Where did it come from?
« Reply #4 on: December 18, 2024, 12:48:31 PM »
Here is one of mine which works.  See if it works better for you.
« Reply #5 on: December 22, 2024, 05:42:43 AM »
So, did it solve your problem?
