Hello Guest it is October 23, 2026, 11:05:25 PM
Author Topic: Help me please! - cannot import DXF, or anything.  (Read 16936 times)
agentforte
« on: April 15, 2006, 04:20:53 PM »
I downloaded Mach 3 and I am unable to import files into the Mach3Mill.  Under file there is only an option to open g code, but for some reason I do not have an option that says "import".  I even tried downloading different versions and still the option is not there.
I am running it from Windows XP, and I'm wondering what the problem is.  Do I have to download any additional software?
Thanks for any suggestions.
-Frank
Re: Help me please! - cannot import DXF, or anything.
« Reply #1 on: April 15, 2006, 06:55:02 PM »
Frank there is a new program that comes with Mach to open the DXF's :) There should be a selection called LazyCAM... This will take in the DXF.
Brian
www.newfangledsolutions.com
www.machsupport.com
agentforte
« Reply #2 on: April 17, 2006, 12:13:59 AM »
Thanks..  I see how to do it now, although it gives me an error when I try to load the dxf...  this might be because the file my friend sent me.  Are there any known issues with importing dxf's that are drawn in other programs?  I believe my dxf file was made in AutoCAD.
-Frank
http://snowboard.skule.ca
« Last Edit: April 17, 2006, 12:16:06 AM by agentforte »
« Reply #3 on: April 17, 2006, 10:37:53 PM »
Frank if you can mail me the DXF I will see if I can fix Lcam to make it load :)
www.machsupport.com
