Hello Guest it is October 25, 2026, 07:43:35 PM
Author Topic: setting up a Z probe to measure tool lenght  (Read 6779 times)
« on: December 01, 2024, 07:18:57 PM »
Hello,
I am working on setting up a tool change probe, I run ESS with a PMDX-126.  In control configuration under inputs I cannot seem to get the active low flag to stay set.  When Mach 4 is enabled the probe LED on the screen is lit and when I press on the tool change probe the led on the screen goes out.  If I press it more I get an e stop like I should.
Every time  I go back in and the setting for the probe to see if it active low it is set to active high.  Their must be some setting I am missing.
Thanks for your help.
Todd
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: setting up a Z probe to measure tool lenght
« Reply #1 on: December 02, 2024, 04:33:22 PM »
Have you checked the ESS settings?
